Help with spark plugs and heads 383 stroker. - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2012, 08:46 PM
New Member
I am having issues trying to decide what plugs to put in this motor. I have a partial build sheet, but think I am missing something to determine this. Per build sheet this is what I know. 383 2-bolt chevy motor bored .030 over, forged TRW piston, rods 5.7 chevy, comp cam tappet lift 286, duration at .050 236 which is the important #? Heads are 76cc 202/160 valves, this is all I have at the moment. I dont know what the compression ratio is, and how do you know what plugs to use with these heads, is there another # on the heads I need to find? Right now it has Autolite 26, dont know if these are correct. Thanks.
Old 04-07-2012, 11:20 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If you have flat top pistons with valve reliefs, .025 in the hole, .041 gasket with 76cc heads your c.r. is about 9.07:1. Have you read your plugs correctly to see how they're performing?
Semper Fi
Old 04-09-2012, 08:39 AM
New Member
The plugs are bad, running very rich I have to adjust the carb. and possible new manifold. But how do you know if you should have extended tip or not? Where are the #s on the head located to determine this.
spark plugs- carb with swirl port heads red82c10 Engine 1 02-23-2012 11:02 AM
spark plugs for 383 stroker cares Engine 2 04-05-2007 08:11 AM
Spark plugs with 041 Heads 70bird Engine 2 10-04-2006 12:54 PM
Edelbrock heads / spark plugs ? driveability Engine 8 03-13-2006 08:29 PM
Shorty Spark Plugs for Vortec Heads?? acr Engine 1 05-13-2005 10:23 PM
