Help with spark problem - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-10-2011, 01:21 PM
0pyders's Avatar
I think I got it.
rotor button to ground stays at 1.
rotor button to battery stays at 1.
New coil then.
Thanks a lot for those links, very helpful.
  #32 (permalink)
Old 04-10-2011, 02:13 PM
LATECH's Avatar
Last journal entry: GTO Reproduction Hood
Check the coil from the other dizzy It may be ok.
  #33 (permalink)
Old 04-10-2011, 02:15 PM
0pyders's Avatar
Nope, crap. It's all crap lol.
I got another one, gonna see if it works.
  #34 (permalink)
Old 04-10-2011, 02:16 PM
0pyders's Avatar
hey should I put any dielectric grease anywhere like under the ignition module?
  #35 (permalink)
Old 04-10-2011, 02:24 PM
ericnova72's Avatar
More for Less Racer
Not dielectric grease, that would hold heat into the module = BAD. You need silicone heat sink compound for under the module, to help transfer heat away from the module.
  #36 (permalink)
Old 04-10-2011, 02:26 PM
0pyders's Avatar
oh ok thanks for the save.
still got a problem.
new coil in and i still can't get a reading from it, just says 1.
I had to reuse the rotor button because the new one didn't come with it, can the rotor button go bad?
  #37 (permalink)
Old 04-10-2011, 03:47 PM
0pyders's Avatar
I got .8 measuring the BATT and TACH.
Using the horseshoe symbol thing at 20k, no readings on either secondary.
  #38 (permalink)
Old 04-10-2011, 05:34 PM
0pyders's Avatar
here's how I installed it. anybody see anything wrong?
  #39 (permalink)
Old 04-10-2011, 07:35 PM
LATECH's Avatar
Looks fine opyders.no problem
  #40 (permalink)
Old 04-10-2011, 07:40 PM
0pyders's Avatar
ok cool, at least I know I put it together right. I'm gonna try and get a new bushing spring thingy, see if that fixes the problem.
  #41 (permalink)
Old 04-10-2011, 08:18 PM
0pyders's Avatar
On my ignition wire that plugs into the BATT of the distributor..
I got 12 volts without cranking but when it cranks it goes down to 10 volts. Could that be the problem?
I just ripped the wire from a broken radio. hmm..
edelbrock pro flo efi problem, no spark blazer69 Engine 0 12-13-2010 05:57 PM
Chevy HEI Problem - I have no spark! Please help guysnydr Engine 9 05-26-2010 12:19 PM
Spark Problem PAS55 Electrical 2 04-05-2006 06:17 AM
Spark problem Trucknut Electrical 9 09-20-2005 05:29 PM
Spark problem. CET Engine 6 04-23-2003 08:52 PM
