Help with spark problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2011, 03:39 PM
0pyders's Avatar
350 chevrolet computer controlled distributor
I don't think I'm getting any spark with it, I don't know for certain. I didn't feel anything holding one of the plug wires in my hand.
I switched distributors (with one that worked last time) and it's the same thing.
The engines out of the car. For the ignition wire I have one end clamped to the positive battery terminal and the other to the part labeled "BATT" on the distributor. the wire has 12 volts without crank and 10 volts cranking. I don't understand please help.
here's my setup:
Old 04-09-2011, 04:35 PM
LATECH's Avatar
Last journal entry: New Gas Tank
You need a jumper from the battery negative to the housing of the dizzy.it has no ground. then be prepared , it WILL make spark.run a seperate gound wire and lay the spark plugs across it with the plug+ wires attached to the cap. Keep it away from the battery at least a couple feet so as not to create an explosion hazard. turn on the battery switch and give her a spin and you will like it.
You can just leave the coil cover off and spin it. The spark will jump to the coil retaining screws without hurting anything, you may get bit so be prepared in case you drop it .
I cant count the times a plug wire bit me. It doesnt kill you but it is a suprise and it stings pretty good.
Old 04-09-2011, 04:53 PM
0pyders's Avatar
running a wire that plugs into the groundstrap of the distributor to the negative battery terminal?
Old 04-09-2011, 04:57 PM
LATECH's Avatar
you can just clamp it to the dizzy housing as that is where it gets its ground from when installed.
Old 04-09-2011, 05:01 PM
0pyders's Avatar
so i can take off the black jumper cable clamped to the block and just put that on the distributor cap somewhere?
Old 04-09-2011, 05:29 PM
LATECH's Avatar
You can clamp it on the housing for the shaft if you like.
I am assuming the dizzy is not in the motor?
Old 04-09-2011, 05:31 PM
0pyders's Avatar
distributor is installed in the motor, sorry probably should have done the picture better. I tried clamping it to the shaft but still still no shocks
Old 04-09-2011, 05:40 PM
LATECH's Avatar
OK I did not realize it was in the block. It has its ground when it is installed in the block so just put the cable back on the block.
There are two terminals that you have to jump on the computer style ignition module to make it run when unplugged from the rest of the vehicle harness. Give me a minute , I will check to see which ones they are , my thoughts are terminal a + c but let me check to make certain.Be right back.
Old 04-09-2011, 05:52 PM
LATECH's Avatar
you have the big distributor with the coil in the cap? correct? and a 4 pin connector coming out also? correct?
Old 04-09-2011, 05:54 PM
0pyders's Avatar
Yes sir that's the one.
Old 04-09-2011, 06:02 PM
LATECH's Avatar
The distributor 4 pin connector has letters on it. Jumper the A" terminal to the C" terminal and then check for spark. It should have it now.
Old 04-09-2011, 06:11 PM
0pyders's Avatar
wait how do I jump A terminal to C? I forgot what that means.
Old 04-09-2011, 06:37 PM
LATECH's Avatar
take a little piece of wire like 16 gauge and strip both ends. Locate pins A and C in the 4 wire connector and poke the wire in the A and C terminals.you know jumper wire.
Old 04-09-2011, 06:39 PM
0pyders's Avatar
ok i see now thanks, gonna try and do this before the suns down.
Old 04-09-2011, 06:46 PM
LATECH's Avatar
get-rr - done LOL
edelbrock pro flo efi problem, no spark blazer69 Engine 0 12-13-2010 05:57 PM
Chevy HEI Problem - I have no spark! Please help guysnydr Engine 9 05-26-2010 12:19 PM
Spark Problem PAS55 Electrical 2 04-05-2006 06:17 AM
Spark problem Trucknut Electrical 9 09-20-2005 05:29 PM
Spark problem. CET Engine 6 04-23-2003 08:52 PM
