Help with sparkpulg wires on cap ??? - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2012, 10:24 AM
I just bought a 1988 chevy 1500 silverado truck 350 I always start at number one plug and go from there, and when i traced the #1 plug wire to the distributor, it was in front of the distributor screw on passenger side or were #4 wire should be i believe. but it was in firing order, 18436572 the distributor does not look like its been pulled out . the guy just put this engine in it from another same year model truck,but havent ran it much cause the truck sat up for about 3 years and had about 10 gallons of old gas and they tried adding new gas but wouldnt hardly run . I had to get tank redone. so i only had a chance to hear it run for about 5 minutes .So should i just put the wires on or move wires to were they should be. and on the cap ,is #1 in front of screw on cap on right side,or the next one going to the left. This is the small cap with coil mounted beside distributor.. any help would be great. thanks
Old 05-29-2012, 05:53 PM
Richiehd's Avatar
JS-70
You move the wires you will have to move the distributer too. Does it run? what is the issue as long as the firing order is right?
Old 05-29-2012, 06:30 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
It don't matter where #1 is located on the cap as long as the firing order is correct and #1 is at TDC.
spark plugs wires distributor cap ravenstorm873 Engine 2 04-28-2009 07:51 PM
HEI Big Cap to Small Cap ericbr Electrical 1 12-18-2006 05:04 PM
Distributor cap flatblaktruk Engine 2 12-29-2005 08:36 PM
tried to put my new msd heli core wires on and they didnt fit my unilite cap???? badk5 Engine 7 07-18-2005 11:37 PM
help sparkpulg won't come out mercflathead Engine 10 06-15-2005 05:34 PM
