Help spraying metallic - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2011, 07:54 PM
Hey guys,
my dad is painting my car tomorrow, Primed and sanded today. My dad has only painted a few cars this being his first with metallic in it. FYI It's single stage plum crazy purple, My question is if God forbid we have any problems, runs,dust,etc is it tricky to wet sand out? I read online that wet sanding metallic can ruin/change the way the metallic looks even after buffing. Also any tips or advice for spraying paint with metallic?
Thanks,
~Nick
Old 04-26-2011, 08:05 PM
CQNRQY
Originally Posted by 69clone
Hey guys,
Thanks,
~Nick
Hope all goes well tomorrow.
Alot depends on the type of paint you are going spray.A single stage paint Enamel for example relies on the way it is laid down.It is what it is when you paint it. Plum crazy metalic is not one of the easiest to do that way.
A base clear would likey be easier a lot more room for fixing mistakes. Your base color can be put down and repaired be for you apply the shine (clear) and if you run the clear it can be buffed wet sanded with no effect on the metalics.
Good luck
Conroy
I may help to use a wide fan/spray setting on your gun when spraying the color and also stay back a little from the car to let the paint fan out more than normal. this may help reduce tiger stipes from happening. Fog in and cross hatch spraying will also help.
Old 04-26-2011, 08:26 PM
Thanks, I don't remember the type of paint. We got it at NAPA they told us it was the most forgiving paint. The only thing about BC/CC was my dad wasn't sure because he'd never done it before...
Old 04-27-2011, 07:26 AM
cyclopsblown34's Avatar
Colorsanding painter
He will need to alternate his pattern he sprays the car at 45 degrees from one coat to the next. He'll also need to overlap each pass by 1/2 of the previous pass.
Old 04-27-2011, 12:15 PM
Thanks I'll let him know, I'm just wondering what can/will happen if we wet sand it/buff it???
Old 04-27-2011, 01:16 PM
jcclark's Avatar
The Penny Pincher
Last journal entry: Hanging Bumpers
Thanks,
~Nick
You can always clear coat it just like basecoat,
I do that, it sure makes buffing safer and gives a little
more UV protection.
Old 04-27-2011, 02:27 PM
You'll cut the edges of the metallic particles and it might affect their reflectivity. I've cut single stage metallic before and polished it and it looked kinda blah and uneven.
Old 04-27-2011, 02:28 PM
Wiki Edits: 27
good light needed
I used to hold a trouble light in one hand so I could see how the paint was laying down. a spark- arc can be dangerous. It would be best if you could rent space in a regular booth with good ventilation and lighting.
Old 04-27-2011, 03:03 PM
Throw some universal clear on there from SPI
Old 04-27-2011, 03:27 PM
Nate is right on the money if you have an extra 100.00 and maybe two days to wait.
Old 04-27-2011, 09:08 PM
Thanks guys,
Now if things don't go our way and it looks like shrt. Is clear coating something I can do anytime? Or do I have a window? Of course it would suck to retape the car, our problem is we are borrowing a neighbors garage which we transformed into a nice paint booth, but he's leaving for Iraq and we won't be able to use it.
Dummy Newb Q--Can I get metallic paint without the metallic? superkaz661 Body - Exterior 4 10-07-2008 04:16 PM
Metallic or Not? 90Cutlass Body - Exterior 3 08-06-2007 08:08 PM
Need Help Spraying Metallic rcm800 Body - Exterior 7 02-28-2007 05:52 PM
Need a good spray gun for spraying metallic base camaro freak Body - Exterior 1 04-18-2006 05:26 AM
Spraying Metallic colors? HOW? novafreek6872 Body - Exterior 7 12-06-2005 10:07 PM
