help squeaking problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2005, 05:51 PM
steve t's Avatar
ex biker, now hotrodder
my 61 impala has a squeak in automatic trans tail shaft or somewhere in area of transmission or drive shaft when you jack it up and turn the rear wheels in neutral. i have greased all universal joints and used wd40 on trans tailshaft seal, and squeak is still there. also i used wd40 on center carrier support bearing. what could the problem be. thanks for any help
Old 07-10-2005, 06:51 PM
Fast Orange's Avatar
When you lubed u-joints,did grease come out of all 4 cups on each joint?If not you may still have a dry cup somewhere on driveshaft.In my experience,if a u-joint is dry enough to squeak,you should probably replace it,as it's most likely to be full of rust.I would go through the u-joints again,replace any that don't take grease all the way through,and replace the carrier bearing while the d/s is out of the car.The carrier bearing is a sealed unit,I believe,and cannot be greased.If I remember correctly,u-joints cost about $14 each,the carrier bearing is about $24 from my local parts store.I did my friends car last year,it took about 2 hours,and all parts were available at the warehouse the same day.
Hope this helps.
Good Luck,George
Old 07-10-2005, 06:59 PM
BigDawgsEatFirst's Avatar
400SBC4Life
My carrier bearing squeaked when it was shot
its rubber was worn
grab shaft and see if u can move it
side to side and up and down
the suspect should squeak
the noise is worn out rubber
like post before said check center support
94 Dodge Transmission Electronics problem? Native Gearhead Transmission - Rearend 7 10-17-2006 10:00 PM
Problem batch loading larger images cboy Hotrodders Site Suggestions and Help 10 03-23-2005 08:26 PM
*&%##*^#!! starter problem solved!!!! 85 vette Engine 12 02-22-2005 08:12 AM
Newest Transmission problem RObs71Nova Transmission - Rearend 4 01-30-2005 07:00 AM
C6 problem galaxieguy3 Transmission - Rearend 3 01-03-2004 09:25 AM
