help with steering shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-20-2011, 05:02 PM
Pupsvette76's Avatar
Last journal entry: no spark and fuel pump issue
ok so i have a 70 nova and im having trouble with my rack and pinion install the rack install is fine but when i install the steering shaft to connect the column to the rack it turned good and smooth but when i connected the tie rods to the spindles it now felt choppy i read up a little bit and saw some stuff about mis-phasing the u joints and i dont know if its better with the anchor for the upper part of the shaft all the way in or out... if any of u guys have any experience with this i would appreciate the help thanks in advance
Old 11-21-2011, 09:15 AM
S10xGN's Avatar
Gotta love a turbo!
This would indicate the joint phasing is correct, how does each spindle turn by hand?
Russ
Old 11-22-2011, 06:19 PM
i havent tried that.... i def feels like a u joint kinking up though none of the angles of the u joint are that severe though
Old 11-23-2011, 09:26 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Woodward says to keep the angle below 20, split it between two if necessary. I'm guessing you know about using paired joints (from wiki ):
And proper phasing:
Old 12-01-2011, 05:55 PM
i have the unisteer steering shaft kit and it comes with a frame mount for like a heim joint and a bracket that bolts in place of your existing steering box bolts...it looks like the bottom u joint is the issue because the angle is pretty severe ... and with the heim joint threaded all the way out it still seem pretty radical plus thats when i start having header fitment issues
Old 12-02-2011, 09:21 AM
S10xGN's Avatar
Gotta love a turbo!
Just for an example, here's a pic of the relocated steering shaft (header clearance) on my S-10. It, too, has two joints with a Heim support.
Russ
Old 12-02-2011, 10:01 AM
evolvo's Avatar
You might want to take a close look at the U-joints and make sure the shaft is not so long that it hits the cross. That will make it feel choppy for sure. How do I know this.........
Old 12-17-2011, 06:13 PM
i got a chance to play with it and the phasing of joints and i got it just right ...its unbelieveable how sensitive that steering shaft is... it was only off by maybe 2 or 3 teeth on the splines once i put the grooves on the u joint at a perfect 90 degrees it was smooth
Old 12-17-2011, 06:30 PM
choppy rack
pull back the rubbers & check that theres nothing in the threads or the worm , if its all smooth until you connect the tie rods check them,Disconnect & try one at a time in case theres a problem one side
b0nes611
36 plymouth steering shaft Hammerhand Suspension - Brakes - Steering 2 09-22-2011 04:56 PM
Steering shaft clearances Hot Rod Mike Suspension - Brakes - Steering 2 07-20-2011 06:35 PM
What steering input shaft is this? marks914 Suspension - Brakes - Steering 5 01-28-2008 08:45 PM
Steering Shaft Question Quarter Flash Suspension - Brakes - Steering 3 09-19-2006 01:36 PM
Steering shaft chiss Suspension - Brakes - Steering 12 01-17-2006 04:03 PM
