Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with steps between body work and Paint
Old 10-26-2006, 06:17 PM
adtkart adtkart is offline
If you want to go with just 2K primer, the SPI Turbo primer is a DTM primer, meaning it can go directly on bare metal. Otherwise, I suggest you use an epoxy primer to cover the bare metal. It can also be used as a sealer, when reduced.
