help with stewart warner wings series 3 3/8 tachometer - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2009, 06:39 PM
Last journal entry: test
I recently bought a 29 ford the ignition was switched to msd 6al with a tach adapter ... but the tach wasn't working... after a little research found that the tach adapter was not needed and that it was wired incorrectly for the new ignition... rewired with out the tach adapter now the tach works but is sluggish as if it was a fluid filled guage... I noticed there are 4 dip switches in the back does anyone know what the setting should be on these switches or what could cause the tach to act slow?
thanks
simon
Old 01-02-2009, 08:47 PM
The switches are usually used to set it for 4/6/8 cylinders.
Bruce
Stewart Warner 240A Fuel Pump bluesman77 Electrical 6 10-20-2009 06:39 AM
Unknown Stewart Warner Tach - Please Help ID dukes69 General Rodding Tech 9 12-01-2008 07:30 PM
Classic or Stewart Warner 327NUT General Rodding Tech 10 11-18-2008 07:05 AM
Which waterpump? Eagle1 Engine 5 08-06-2004 06:38 PM
stewart warner gauge buds53 Hotrodders' Lounge 1 05-12-2002 05:46 PM
