-   -   Help with suicide door hinges (http://www.hotrodders.com/forum/help-suicide-door-hinges-110608.html)
dwhip 03-05-2007 06:12 PM
I'm lookig for any info on suicide hinges, what kind have you used, did you like the quality, how hard to install etc... any help would be great. Thanks, Dave
Hot Rod Mike 03-05-2007 07:53 PM
suicide door hinges
Dwip,
Are you interested in original external hinges, or the hidden hinge kits offered by many vendors ?
Mike.
dwhip 03-06-2007 08:34 PM
I'm looking for the hidden hinge, aftermarket type.
Streamline55 03-06-2007 08:47 PM
Check out suicidedoors.com
powerrodsmike 03-06-2007 09:11 PM
Speedway motors has a set that are easy to install and set up.
http://www.speedwaymotors.com/p/3067...or-Hinges.html
I've used them before and they work.
Later, mikey
Stray Catalyst 04-03-2007 01:47 PM
Originally Posted by Hot Rod Mike
Dwip,
Mike.
I'm interested in reusing the hinges on my present project car, if possible. It's a 1974 VW Beetle, with the usual exposed hinges. I'm ok at welding, and have access to a sheetmetal prototype shop. Any advice?
Stray Catalyst
