Help with suicide door hinges - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-05-2007, 06:12 PM
Last journal entry: Resizing the rear window
I'm lookig for any info on suicide hinges, what kind have you used, did you like the quality, how hard to install etc... any help would be great. Thanks, Dave
Old 03-05-2007, 07:53 PM
suicide door hinges
Dwip,
Are you interested in original external hinges, or the hidden hinge kits offered by many vendors ?
Mike.
Old 03-06-2007, 08:34 PM
I'm looking for the hidden hinge, aftermarket type.
Old 03-06-2007, 08:47 PM
BigMike
Check out suicidedoors.com
Old 03-06-2007, 09:11 PM
powerrodsmike's Avatar
Wiki Edits: 161
Speedway motors has a set that are easy to install and set up.
http://www.speedwaymotors.com/p/3067...or-Hinges.html
I've used them before and they work.
Later, mikey
BE different....ACT normal.
Old 04-03-2007, 01:47 PM
Originally Posted by Hot Rod Mike
Dwip,
Mike.
I'm interested in reusing the hinges on my present project car, if possible. It's a 1974 VW Beetle, with the usual exposed hinges. I'm ok at welding, and have access to a sheetmetal prototype shop. Any advice?
Stray Catalyst
US President to support Terrorism in his fight against Terrorism, Irony at itís best. wizzonial Off-Topic 50 02-25-2006 08:55 PM
Suicide or not chevyhotrod Body - Exterior 8 09-06-2005 07:05 AM
79 Town Car Suicide Doors Bill Klooster Introduce Yourself 4 12-27-2004 05:14 PM
suicide rear doors over wheel well? flamedfordbronco Body - Exterior 8 02-20-2004 09:11 AM
Suicide Doors 50Windsor Body - Exterior 1 07-17-2003 07:31 AM
