Demon carburetor Get parts for cheap, all for a good cause.
Parts auctions to protect free speech online.
Click here for details.
Parts currently up for auction: Rat rod chassis parts, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Suspension - Brakes - Steering
  #1
Old 08-21-2008, 12:39 PM
Bob88's Avatar
Bob88 Bob88 is offline
New Member
Help with suspension
Hey guys need some opinions on suspension. Take a look at the pics and tell me why this frame is riding so high. What do I need to do to lower it. Appreciate any help.
Bob
Size:  227.5 KB  Click image for larger version
Old 08-21-2008, 01:41 PM
84 Monte Carlo's Avatar
84 Monte Carlo 84 Monte Carlo is offline
Auto Tech
re: Help with suspension
add weight to it
Old 08-21-2008, 03:04 PM
home brew's Avatar
home brew home brew is offline
Just Plain Nashty
 home brew's barnstar
I'm not sure what frame that is and what body is going on top of it. That might make a difference in the answers.
You could use lowering blocks between the rear axle and the springs which would raise the axle up and lower the frame closer to the ground. You could also use flatter springs with less arch to bring the rear end down. Another way would be to change the mounting of the springs to the sides of the frame instead of under the frame. Or you could do any two or all or these suggestions.
Old 08-21-2008, 06:26 PM
Bob88's Avatar
New Member
It's a 29 chevy 3 window coupe. I wondered if that would be enough weight to lower it down some. I thought about the lowering blocks, but would'nt that only give me a few more inches. I guess I'll wait till I get the body on before I decide what else to do. Thanks for the help.
Old 08-21-2008, 07:27 PM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Yup One of those Moderator's
 OneMoreTime's barnstar
Wiki Edits: 3
Just a tip..when I set a frame on the frame jig I block it to the finished ride height then if it needs to be raised a bit i find that a lot easier to do..Watch the scrub line as that needs to be maintained..Last one I built came of of the jig and needed very little adjustment..
Sam
If it don't work it ain't pretty!!!!
Old 08-21-2008, 08:43 PM
Cape Cod Bob's Avatar
Cape Cod Bob Cape Cod Bob is offline
Hey, I thought that frame looked chevy.
I had the same problem with my 31. Had the stock springs rearched and way to high.
I went and put in a chassis eng, universal rear spring set up. I mounted the rear perches just in front of the stock ones. Used a hole on the frame to locate the front perches that the stock perches used, and drilled new holes for the other. Their kit is a weld in , but I opted to drill holes in their perches and bolt it in.
I now have the full weight of everything excep the rear seat(its a sedan).
The springs are almost flat now and the ride height is perfect. I have 28 inch tires on the rear and almost 2 inches clearence to the fender lip. @ inch blocks would put it in the weeds.
The stock springs were also flat before I took it apart.
Old 08-22-2008, 08:20 AM
Frisco's Avatar
Frisco Frisco is offline
Glad To Be Here
Reverse the direction of the rear shackles so that the spring "eye" is above the rear shackle frame mount. This will drop the rear of the frame down quite a bit.
The way you have them installed now is what used to be done to raise the rear of a vehicle "on the cheap".
Old 08-23-2008, 08:06 AM
Frisco's Avatar
Glad To Be Here
Bob88 sent me a photo of his rear shackle mounts. See photo below. He asked for a further explanation of what I posted above.
From his photo it appears that there is not enough room to reverse the shackles without some modifications to his frame.
I have attached a sketch to illustrate what I was suggesting and is something that was and can be done on some vehicles. I did this myself on a 1954 Ford to raise it because of sagging rear springs.
He does have some other options.
He can modify the frame.
He can use a de-arched set of springs.
He can install lowering blocks.
If lowering blocks are used care must be exercised to keep the ends of the 'U' bolts from being too close to the ground and a sway bar should be considered because side to side sway is increased when using lowering blocks.
Size:  101.9 KB  Click image for larger version
Old 08-23-2008, 09:21 AM
Bob88's Avatar
New Member
Looking at your diagram I see that my springs are already reversed. Like I said in my pm, looks like I'll wait till the body is on and then probably go to different springs if need be. Appreciate all the help.
Bob
Old 09-06-2008, 04:35 PM
ScoTFrenzel ScoTFrenzel is offline
He can also raise the forward pivot point
and use reverse eye springs.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Help with suspension"
Narrowing a '73 GM B-body Front and Rear Suspension hduff Suspension - Brakes - Steering 2 09-09-2007 08:56 AM
who wants to build their own Mustang II front suspension? measurements inside !!! lowROLLERchevy Suspension - Brakes - Steering 1 09-07-2006 08:33 PM
Help...rear suspension design questions FrankR Suspension - Brakes - Steering 1 06-02-2006 07:50 PM
Hotrodders Knowledge Base: Suspension - Brakes - Steering Jon Suspension - Brakes - Steering 0 11-26-2005 06:29 PM
how to hang a C- 4 suspension ? Redmist Suspension - Brakes - Steering 1 12-31-2004 11:48 AM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
