Originally Posted by 39chevy
On my aftermkt column blinkers, I have a brown and orange wire going to the back of the vehicle and with my test lite when I pull either blinker left or right my wires both blink, why? Whats wrong?
Where does your circuit get it's ground from? Is the column blinkers grounded through a wire to the body? Does it touch bare metal on the column?
Did this work at one time? Did you do anything recently to change things?
Another que. with Led lites they have 2 leads coming from them, do I put both together because when lite is installed it picks up it's ground that way? Thanks for any info, Dana
No! LED's require a positive source on one lead and a way for it to go to ground through the other lead, but usually there's a resistor in the circuit. They are also polarity sensitive, so hooking them up wrong will cause them not to work and possibly damage them.
Post some more details and history and we can help you better.
Steve
