Help! There's a squirrel in my car - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-24-2005, 04:49 PM
New Member
I'm pretty sure the squirrel is gone now. I've cleaned out the car as much as I can (even took out the blower motor and cleaned that area out too) but how do I get rid of the smell?
Short of nice fire, I mean.
Old 09-24-2005, 06:58 PM
have u tried frabreeze
Old 09-24-2005, 07:22 PM
WakBordr7387's Avatar
Gone fishin'
Last wiki edit: Removing stuck fasteners
Last journal entry: blah.......again
Wiki Edits: 2
I can't remember where I heard it from but this works for me, I just put a sheet of fabric softener under the seat for a few days. I dont have to scrub or nothing just leave it over night and should help the smell some.
Brad
Old 09-24-2005, 07:59 PM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
what does it smell like?
I would buy some upholstery/carpet cleaner and clean the interior.
Old 09-25-2005, 07:16 AM
New Member
The smell is coming through the vents when I use the AC or heat. It smells like a pulp mill or wet cardboard. Its kind of a mouldy smell.
I wonder if anyone makes a spray that you can spray into the vents to kill mould (I think the Ford Escorts and Taurus' have had this problem from time to time). Any suggestions?
Old 09-25-2005, 09:16 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Ultrashield
Hi,
There is a product named Ultrashield which is used to eliminate odors caused by mold in A/C systems. I stock it at our NAPA store in 2 fragrances ... baby powder is one of them, and I think spearmint is the other.
http://www.ultrashield.com/odortreatment.html
Make sure that you have cleaned up whatever the source of the odor is as well.
There is another product called Evap-Clean that is made by Cliplight. It apparently completely removes the mold on the evaporator, and restores it's cooling efficiency.
http://cliplight.com/freshairproducts.php?pageID=Evap_Clean
One more thing. Many small rodents etc (I'm not sure if this includes squirrels) can carry hantavirus. If you're in there cleaning things out, I suggest using a dust mask and latex gloves as protection.
HTH,
Don
Old 09-25-2005, 11:45 AM
New Member
I took the cowling covers off and cleaned out the nest that I found there (Using gloves, etc). Then I sprayed the area with 50/50 bleach and water. I took the blower motor out and cleaned the impeller blade. I think I got it all. Thanks for the help. I'm going to check out the spray from NAPA tomorrow.
Old 09-27-2005, 04:56 AM
New Member
For interest sake, the spray from NAPA (Ultrashield) worked very well. Within 24 hrs there was very little odor left. The website indicates it takes about 72 hours.
1985 LTD 302 V8 Cheap begginer project car 1stPROJECTcar Engine 5 05-27-2011 03:18 PM
head gasket replacement now car won't start jesse01 Engine 10 04-28-2007 05:53 AM
How much Torque need to lift front end? unstable Engine 22 02-20-2003 09:54 AM
