Help on THM 400 - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-27-2007, 10:22 AM
Help on THM 400
I recently purchased a B&M holeshot 2400 torque converter and they said that if my 400 has a variable pitch that the pump and input shaft has to be changed to a fixed pitch?
What are they referring to? I have also purchased new pump for this transmission and no one here can tell me if it a variable or fixed pitch.
The box started making a humming sound and then I lost all gears, oil is black and smelly, so the clutches must have gone as well
Any info???, please help!!!
Old 08-27-2007, 02:08 PM
th400
The pump you purchased, you may not need. The trans will whine, maybe hum, if the filter is stopped up, because of clutch failure.
The variable pump has not been in use for some time now, about 30 years or so. If it is a variable pitch pump it will have a solenoid on it.
You said no one here can tell you, Vuka, where are you?
Old 08-27-2007, 11:45 PM
Over here in Port Elizabeth South Africa.
The box was rebuild and fitted with ray bestos clutches.
We done only two races with it. A Transpack system was also fitted
The old clutches we took out still had the make, date etc on it.The trannie was purchased as a cut-out from USA about 3 years ago, we just flushed it and raced the next day no problem.
Shouldn't have fixed something that's not broken??
I think it is the pump, as the oil was hot after the race, but the cooler and lines was cold there was no indication that the clutches was going no slipping or anything just in the final on take off there was nothing 1,2,3 or reverse????
Old 08-28-2007, 07:14 AM
Will I ever get it done?
Last journal entry: Hood
If the tranny is out and the converter has been removed, the quickest way to identify a switch pitch is by the stator support. The splines on a switch pitch are approx. half the length of a standard converter support. I have attached a photo of a switch pitch. Note how short the splines are on the stator support.
Old 08-28-2007, 07:42 AM
Nice picture, thats it.
400 cid SBC Shades_o_Grey Engine 20 02-04-2008 01:28 PM
my turbo 400 won't shift!! skylark65 Transmission - Rearend 2 07-01-2007 08:58 PM
383 or 400?? KFXrider88 Engine 7 06-13-2006 06:45 AM
THM 400 Questions Fast Orange Transmission - Rearend 3 03-07-2006 08:09 AM
thm 400 mount 88 olds Transmission - Rearend 0 11-11-2003 09:48 PM
