Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with throttle body on 1992 1500 silverado??
Old 05-26-2009, 07:34 PM
Robbie's Avatar
Robbie Robbie is offline
Last journal entry: nova
i have checked all the grounds straps,and retighten them,and even ran another ground just to make sure,if the ground was bad,it wouldnt run right??
and yes,me pumping the gas kept it running..The ground i checked was on the passenger side firewall going from the frame to the firewall to the engine,and the other was near the battery,and another one was on the intake.
Originally Posted by T-bucket23
Pumping a fuel injected vehice should have no effect. Check teh voltage the the injectors. Use the injector ground to the injector + it should show a good strong pulse. If the 12 volts is solid and the pulse doesnt look good, the ground is bad. This is common on these trucks. It is the ground for the computer theat the injector groung pulls up to. If you can get a schematic, it should be easy to find. Check the Autozone site, that have a lot of schematics for that vintage vehicle.
