Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with timing Chain and timing cam install
Old 12-08-2006, 06:44 PM
327NUT's Avatar
327NUT 327NUT is online now
I strongly suggest you beg, borrow or buy a motor manual for your particular engine and read the timing chain R&R section before you even attempt to tear into it. It isnt hard, but if you have never done it before and are not very familiar with engines then I believe you would be in over your head. Or..get a knowledgeable person to help you, good luck
