Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help with timing Chain and timing cam install
Old 12-08-2006, 08:25 PM
327NUT's Avatar
327NUT 327NUT is offline
No real tricks, just read the R&R section, you'll need a harmonic balancer puller, and a gear puller for the crank gear. Make sure the dots on the crank gear and cam gear are at 12:00 o'clock and 6:00 o'clock respecfully by ticking the starter till they line up vertically before you remove the cam gear. You'll also need a harmonic balancer installation tool, DONT beat it on with a hammer.
