Help with timing! I'm Electrically Challenged - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-22-2012, 09:14 PM
I'm great with mechanical and suck with electrical. Planning ahead for when I start my 327 for the first time to break in the cam. I'm confused about setting initial timing. I'm reading it should be set at 12 - 14 degrees initial. When I start the car and take it to 2000 or 2500 rpm, do I start it and then disconnect the vacuum advance and set at that number at the break in rpm? Do I start it with the vacuum disconnected? Does it matter? Is there a way to get it close by setting the distributor to a certain position before starting it? Does anyone know of a step by step tutorial that explains how to do this? Sorry for all the questions but I don't want to screw it up. Thanks
Old 04-23-2012, 04:36 AM
Just to add a little emphasis to F-bird 88s suggestions
- Definitely disconnect and plug the vacuum advance line.
- If you line the timing pointer up to about 12-14 degrees BTDC on the balancer and then drop the distributor in so that it is pointing to number one on the cap, you have a good approximation of the timing advance you need. It should at least be close enough to get it to run for the break-in.
When I broke in my last cam the engine started to run hot before I got through the suggested 30 minute break in. I just shut it down and restarted to complete the break-in after it cooled, and it worked fine.
Bruce
Old 04-23-2012, 06:48 AM
Thanks. That's some very helpful stuff.
Old 04-23-2012, 08:18 AM
Greg T's Avatar
www.krusinklassics.net
Quickest way I know is to put #1 on TDC compression stroke. Remove #1 plug and ground it. Connect the plug wire.
Bring your timing mark on the balancer to 14 or 16* BTDC, turn on the ignition switch, with the dist loose turn it until you see the plug fire. Snug up the dist cus it's close enough to run perfectly until the cam is broken in.
Old 04-23-2012, 08:57 AM
That sounds so simple even I shouild be able to handle it. Thanks!
fully manual, electrically shifted 4L60E ? Augusto Transmission - Rearend 15 05-22-2007 02:43 AM
Timing sbc corvette timing at 12o clock on both gears? 85 vette Engine 21 12-22-2004 08:23 PM
trying to setting the timing on the timing chain and gears on a 74 ply with a 318 ReggieN Engine 1 10-05-2004 07:54 AM
i'm mentally challenged badknuckles Engine 14 06-22-2004 12:35 PM
out of the closet.... (electrically) Sleeve396 Electrical 4 04-28-2004 09:05 PM
