Help with timing - Pontiac 455 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-27-2011, 11:40 PM
I installed a Pontiac 455 in my 65 GTO, and I realized I have no idea with this combo what a good starting point for my timing would be. I am pretty sure the initial timing is going to want to be higher than stock (which was 12 degrees, IIRC), but it has been a while since I worked on anything and I just want a decent starting point. I will eventually have it dyno-tuned, but for now it is just me.
455 @ .060 OB
Heavily ported 6X heads, 2.11/1.77 valves
9.75:1 compression
Performer RPM
Holley Street Avenger 770 cfm
Cam Specs:
Int Duration @ .050 - 230
Exh Duration @.050 - 234
Int Lift - .505
Exh Lift - .510
Lobe Sep. 111.1
Old 10-28-2011, 12:16 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You may end up using more, but I would say to start at 16º-18º. Keep track of your total timing as you tune. Keep the vacuum advance at 10º or so. I had a very similar combo (9.25:1, Performer (not RPM) w/4777 650 cfm Holley, 108º LSA, couple more degrees intake duration on a single pattern cam, Rhodes on intakes only, 1.66 exh.valves, 6x-4 heads were only about 175cc intake ports after I was done porting them), it ran effortless 12.7's w/a 3.31 rear gear in a '81 all steel Camaro. Shifted at 5000 RPM. It was timed 18º initial and 34º total.
Old 10-28-2011, 07:54 AM
DENCOUCH's Avatar
Pardon me please
not meaning to hijack the thread, but I have a question about the headers used in the 455 swap. What worked for you cobalt327?
Old 10-28-2011, 10:14 AM
Timing
Cobalt: What exhaust did you use with that combo? I have Doug's on mine, and they fit fantastically, but mine is obviously Pontiac/Pontiac.
After messing around with the engine this morning, it seems like it really likes a lot of initial timing to idle decently - around 20-22 btdc. At that point it manages to pull about 13 inches of vacuum as well.
In addition to having higher compression and 1.65 Roller rockers, and bigger valves, it also has a Hydraulic Roller, not a flat tappet, so the valve openings/closings are much more aggressive as well. I might even go more in the future but want to keep the power brakes without having to use a vacuum pump.
I am running a 200-4R with a Ford 9" 3.55 gears. With a fiberglass hood and other mods, as well as it being a convertible, it is actually a fairly light car at approximately 3300 pounds curb weight.
Old 10-28-2011, 01:00 PM
WDCreech's Avatar
Grumpy Old Goat Herder
20-22 btdc with or without the vacuum advance conected? Initial timing is always w/o vacuum advance.
Without vacuum of course. And at ~800 rpm.
Old 10-28-2011, 02:17 PM
WDCreech's Avatar
Are you sure that the outer ring on your balancer hasn't slipped?
Old 10-28-2011, 02:18 PM
That has occurred to me. And no, I am not sure. I probably should check it.
Old 10-28-2011, 04:47 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I used Hedman 4-tube headers from Summit, I just looked to get the part number, but none are like what I bought- mine were a standard bolt- on collector, not the ball and socket type they sell now. But they were the standard painted headers, nothing fancy, 1-5/8" primaries. If I had it to do over, I'd have used more carb, an RPM intake and 1-3/4" headers- although I really am on the fence regarding the header primary diameter, 1-5/8" seems small for a 455, but w/the low shift point...
The exhaust was 3" from the collector w/an "H" after the collector, before the Flowmaster mufflers. The muffs had a simple 3" turn-down about 10" long that exited just before the rear axle. In other words, the mufflers were as far rearward as the chassis would allow. Oddly it didn't have any interior drone, although it would set off car alarms any time I idled through a parking lot. One of my evil pleasures was to idle through the local mall in front of the theater.
My short time (60') was 1.7 seconds, matted it from an idle. Tires were L60 McCreary's (now made by American Racer Tires). I had a lot of fun using McCreary tires on the street. I could put 4 lengths on a guy, w/o breaking the freaking speed limit!
The McCreary's were made for dirt track or drag racing, but they do have a DOT number. In BIG lettering it reads "ROAD STAR".
This is also on the sidewall (check out the Treadwear rating):
These days there are plenty of good drag radials to use (these are bias), so traction shouldn't be that big of a problem.
? Pontiac 400 Timing Set beertracker Engine 9 12-11-2010 08:41 PM
Timing a 75 Pontiac 455 badams_iyns Engine 3 11-29-2008 10:18 AM
pontiac timing Blob Engine 5 06-24-2006 05:54 AM
timing on a pontiac natas Engine 3 08-09-2004 06:38 PM
pontiac timing 67bird Engine 11 02-10-2004 09:11 AM
