Help!!!!!Timing problem?????? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-30-2010, 10:42 PM
OK I got a 74 Chevy 1500 350 4x4 I just replaced the timing chain and gears. I put it on acording to the directions I made sure i was a top dead center and aligned the marks on the gears up, put it all back together. pulled the cap off distributor and the rotar was pointing at 12oclock straight at my firewall. so i pulled the distributor out and turned the rotar till it was close to my number one spot and reinstalled it hooked up all my wires and tried to start it. it cranks fine but wont start it either backfires really loud or shoots a flane out of the top of the carb. ive tried rearranging the wires and moving the dirtrubutor but no luck im running out of ideas please help!!!!
Old 04-30-2010, 11:07 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Take the #1 plug out, place your finger over the plug hole and have someone slowly turn the engine over (preferably with a socket on the crank bolt). Turn it until you feel the pressure stop. That will be close to TDC, at least good enough to get it started. Now remove the cap and see where the rotor is pointing. It should be pointing about 5:00, if not, remove the distributor and line it up. Firing order is 18436572
Old 04-30-2010, 11:11 PM
automotive breath's Avatar
On a SBC the timing chain sprocket marks line up with No 6 cylinder at
TDC compression thats why you are having the problems.
Old 04-30-2010, 11:18 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Had you left it alone, you'd have been fine- as said, when the timing marks are aligned closest to one another, #6 is firing.
Just reset the distributor by finding TDC #1 firing.
Old 04-30-2010, 11:33 PM
ok so move my harmonic balancer till its alinged with zero that should be TDC. then look where my rotar is pointing and atatch # 6 wire to it and continue clockwise with the firing order or do I have to pull the distrubitor out again.
Old 04-30-2010, 11:40 PM
timing
Noooooooo! finger in hole of #1 turn motor over till compression stroke pushes ur finger out.(make sure dizzy has no power tho) when it does push it out you can look at harmonic to see how close tdc is on the harmonic. then follow the firing order as said earlier. since you moved the wires around best to pull them off and start from scratch. while at tdc make sure the rotation of rotor for plug wire sequinc and then make sure rotor is pointing @ #1 if not pull the dizzy and reset it so it does. hook up pwr to coil and fire away!
Old 04-30-2010, 11:42 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That will work- provided that you got it out exactly 180 when you first changed the firing order.
If you're sure, then just go to TDC. This will be either #6 or #1 firing. If the rotor is pointing at #1, you know that it SHOULD be #6, so wire the cap to reflect that fact. Same thing if it's pointing at #6- you now know it should be pointing to #1, so make that terminal the "new" #1, then wire the cap CW, 1-8-4-3-6-5-7-2. No need to remove the distributor.
Or for that matter, forget TDC. Just pull the wires from the cap, making note of what terminal is NOW #6 and mark it as #1, then plug the wires back into the cap from this "new" #1.
Old 05-01-2010, 12:02 AM
timing
yeah what he said too! lol! your way is faster and easier as long as he doesnt get confused about rotor not pointing at #1.... but ur method will work real well too!
Old 05-01-2010, 12:53 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
I was typing as you were posting, same basic deal, though!
Torque converter problem??? blacklabzeke Transmission - Rearend 2 12-31-2008 03:55 PM
overcharging problem on 1972 mustang DaSouthWon Electrical 6 08-27-2008 08:17 PM
small blcok chevy! The ultimate starter problem! S.O.S. sugar ray Engine 11 07-19-2007 08:07 PM
I'm having a primer adhesion problem on one door Ripped Body - Exterior 10 06-08-2007 12:45 PM
96 Plymouth Voyager spark problem? baddbob Electrical 12 05-19-2007 03:44 PM
