help with timming - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2009, 04:16 AM
surffix code
and if anyone can find this surffix code v0103ARH i thank you
Old 07-21-2009, 09:44 AM
If your R is a K then it's a Flint built engine on January 3rd, 1989 as an LO3, TBI, 305 in a Firebird.
Bogie
Old 07-21-2009, 11:29 AM
the way it read on the tab is V0103ARH the ARH is captialized and then the casting numbers on the back are 14093638...350...87-95...2 bolt...Roller, one-piece rear seal
Old 07-21-2009, 12:24 PM
My data does not have a ARH code listed anywhere, only AKH comes close. I have a paper listing at home which might have more codes, I'll look when I get home to night, unless somebody else can crack this by the end of the day.
14093638 casting can be built as a 2 or 4 bolt, 350 block. It is roller provisioned but as built can have a flat tappet cam. If it went into a car it got a roller cam, if into a truck a flat tappet.
Bogie
Blower Timming Question, need Help!! Ratoflic Engine 10 04-14-2009 08:04 PM
how to set my timming trigger piston Engine 2 08-13-2008 02:40 PM
Beginner Question (timming) Ratoflic Hotrodding Basics 5 02-01-2005 03:28 PM
timming the beast johnsongrass1 Engine 6 01-26-2003 11:02 AM
Timming Angie Engine 2 11-08-2002 06:21 PM
