Help with torque converter?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2006, 07:17 PM
Half Breed's Avatar
Even my lawn mower is fast
Hey all,
I have a 406 sbc about 550 hp, also will eventually have a 200 shot of nitrous. I also am running a TH400 tranny, how crazy will I have to get with a converter?? Steel stator, anti ballooning plates?? Can someone reccomend a part # manufacturer?
Thanks
Old 01-31-2006, 07:37 PM
tombo615's Avatar
is your car a pure race car? or is it street/strip?
in either case, i highly recommend an ati convertor, they custom make them specifically for your setup, with 100% guarenteed stall speed
www.atiperformanceproducts.com go to the site, and look at the specs that you must know for the convertor, then give them a call
best of luck
Old 01-31-2006, 09:27 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
The competent converter shops all build to engine spec when the application calls for it.
With a 200 shot you will need anti balloon plates, spot brazed or furnance brazed fins
You will need car weight , gear ratio , cam shaft specs, other related information when you call a converter company.
Old 01-31-2006, 09:36 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I strongly suggest Continental TC here in SoCal. Can't find a website right now, but look them up.
Old 02-01-2006, 04:59 AM
Half Breed's Avatar
Car is more for the strip, but will see some limited street use.
Old 02-01-2006, 12:38 PM
If your racing/cruising...
I too would recommend going with a ATI converter. I am very satisfied with mine, also have many other parts from them without any thing negative to say.They are precise, so be prepared to answer lots of questions. I live near thier shop here in Maryland so I just dropped off my info and picked up my converter a few days later.
atiperformanceproducts.com.
410-298-4343
Not advertising just my .02
Old 02-01-2006, 07:27 PM
Half Breed's Avatar
Thank you all
Torque converter, diesel vs gas pjd Transmission - Rearend 4 09-10-2005 08:52 PM
torque converter IDENTIFICATION 327amc Transmission - Rearend 5 03-26-2005 06:23 PM
Is my jeg's brand torque converter a dud? elukas Transmission - Rearend 5 10-07-2004 11:08 AM
Torque Converter Application BMRIde85 Transmission - Rearend 4 06-17-2004 02:57 PM
C5 or Torque Converter Bad? k2mooch Transmission - Rearend 2 11-30-2003 08:27 PM
