help with trans - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2008, 12:14 PM
Minace21's Avatar
help with trans
alright I got my trans in i put 6 quarts in there was already fluid in the torque converter but i dont know how much i backed it out of my shop i drove it around the block to get it hot not knowing that the line wasnt fully connected to the radiator(my dumb mistake) and was draining so i brought it back to the house and the linkage will not go into reverse or park but it will go into the rest of the gears does anyone know how to fix it
Old 02-22-2008, 12:51 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi,
I think it would be useful if we new what it is
your working on.
The next time you do something to your car that
involves fluids & sealing, just move the car outside & let it idle, it will come up to operating temp soon enough, you can't look for leaks while driving down the road.
Take care,
Rich
Old 02-22-2008, 01:00 PM
Minace21's Avatar
thanks man but the point is i do everything on my own and im learning as i go but thanks anyway
Old 02-22-2008, 01:57 PM
help with trans
Minace21, please answer the question about what type of vehicle it is that you are working on, so we can help you.
Old 02-22-2008, 02:22 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
What vehicle? What trans? If you unhook the linkage can you shift it?
Old 02-22-2008, 11:36 PM
Hi Minace21,
Maybe you took the second part of my reply the wrong way, here's the reason I told you that.
I drained the oil in the F150 4x4, got up with the plug went to the bench wiped it off & set it down, started talking to someone & opening
oil cans/bottles, forgot all about the plug, put two quarts in walked back to the bench & saw the plug, suppose I didn't see the plug & put the other 4 quarts in & went for a ride,
what do yo think would have happened?
Rich
Old 02-23-2008, 02:59 PM
Originally Posted by richard stewart 3rd
Hi,
your working on.
He is working on a 700R4 automatic transmission ...
And it is whipping his behind ...
Old 02-23-2008, 03:18 PM
Gotta tell this on myself & another *********, while in the army I had to help a motor pool mechanic,change oil in some duce and a half's, well he set two 5 gallon pails on the fender, I climbed up on top of fender with the oil, he went under and pulled the plug and drained the oil, and a while later he climbed up on the other fender and we proceeded to pour the oil in the motor, I pulled the stick after about half the first 5 gallon bucket, nothing on stick, so we proceeded to pour and stick, pour and stick,etc. till both buckets were gone. I thought to myself this mother takes a lot of oil!
Have you ever seen how big a puddle 10 gallon of oil will make on the floor? I felt like killing him, not for the mistake,but for having to clean all that stuff up.
Hi Minace21,
Rich
Old 02-23-2008, 05:07 PM
Hay Minace,
Have you tried what Henry asked?
Rich
Old 02-25-2008, 10:19 AM
Minace21's Avatar
Sorry guys i was at home all weekend and i only have internet at school and i gotta kinda wait till my teacher gets off my *** before i can get on here
First of all its a 700r4 transmission when i take the linkage off i still cant get it to shift up into reverse or park do yall thinks its gone or can i fix it
Old 02-25-2008, 01:39 PM
Lost in the 60's
Wiki Edits: 4
Have you tightened the line and filled it back up with fluid and tried it? If it still does it then its probably done for and needs to be re-built. Without fluid it does not take very long to burn them up.
Old 02-26-2008, 11:25 AM
help
Minace, let]s qualify this concern. When you say the linkage will not let it go into reverse or park and you have taken the linkage off and still can't move it into reverse or park, this should have nothing to do with running it low on fluid.
The trans may be toast, or not, but you should still be able to move it into and out of these ranges.
If the trans moves forward ok when it is full, but still won't go into reverse or park, you will need to pull the pan and see what has come loose or is missassembled.
Old 02-26-2008, 12:06 PM
Minace21's Avatar
ya im restoring a 67 chevy with my friend right now and were on a tight schedule right now but as soon as i can get to it ill post
Old 02-28-2008, 10:27 AM
Minace21's Avatar
hey guys thanks for all the help i figured it out tho there was a piece of metal wedged into the column that the rod thats on the linkage goes into i got a magnet stick and took it right out of there runs perfect
4x4 1994 Trans problems ???? sinlow1980 Transmission - Rearend 2 07-16-2007 07:37 PM
4t60 Trans Question david hill Transmission - Rearend 1 04-10-2007 09:58 PM
Allison Trans deseldr Transmission - Rearend 5 10-19-2003 08:45 PM
Fine Metal in Trans (NEW) bigjoedo Transmission - Rearend 1 08-09-2003 02:23 PM
Fine metal in trans bigjoedo Transmission - Rearend 21 07-28-2003 12:50 AM
