HELP!!! Trans ID - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-20-2003, 01:19 PM
Weimer's Avatar
Kenneth Howard hates you...
Last journal entry: door pics smaller
HELP!!! Trans ID
I am needing a little help ID'ing a GM Transmission.
4spd Casting # c-95946K
There are #s on a tag on the side also:
647120 GL 35B
5 22 69 435
The bellhousing is cast iron and has #s GM6 3925505
Any help would be greatly appreciated.
Thanks,
WEIMER
Old 06-20-2003, 01:54 PM
gm 4 spd automatic transmission identification
what shape is the trans pan? and it IS automatic - correct?
robin
Old 06-21-2003, 12:31 AM
Weimer's Avatar
No, it isn't an automatic...It is a 4spd. There isn't a transmission pan.
Sorry if I sound short but all of the info that I have is posted above. I will try to post some pics when I get a chance.
Later,
WEIMER
Old 06-21-2003, 07:02 AM
302 Z28's Avatar
Aluminum or cast iron case on the trans? If it is aluminum there is a chance it's a Muncie.
Vince
Old 06-22-2003, 08:38 AM
Weimer's Avatar
Here is a picture of the Transmission...I am wanting to know what applications it is used for and what it is...I have NO IDEA!
It has NP on the top and side, it is cast iron and has a cast iron bellhousing.
Thanks again
Later,
WEIMER
Old 06-22-2003, 09:28 AM
Weimer's Avatar
Well, I found out what it is...
Its a NEW PROCESS 435 Trans. Date code of 5/22/69
They were used in GM, Ford and Dodge trucks.
Granny Gear 1st gear.
Has a GM Bellhousing for the GM apps.
I was told that it is 'desired to be had' by the 4wheeler guys.
Not my thing...won't work in my application.
If anyone is interested in it, let me know...we'll work something out I'm sure.
Later,
WEIMER
