Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help: Transmission ID
Old 07-25-2006, 01:33 AM
jimfulco jimfulco is offline
http://www.dandltransmission.com/saginaw.html has Saginaw ID info. Count the annular rings (if any) around the splined area of the input shaft, and you can get the internal gear ratios from the chart.
