Help with trunk hinge - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2012, 12:37 PM
OK, I'm going with a fiberglass trunk lid for my 31'. I'll be using an external hinge for looks and ease of use. Bolting the hinge to the body will be no problem as it is metal. My concern is that bolting the hinge through the fiberglass trunk may cause the inner & outter panels of lid to collapse. I'm thinking some kind of spacer is necessary to avoid this. I'm sure I'll think of something eventually but has anyone delt with this and have any ideas for me? Thanks.
Old 05-02-2012, 12:52 PM
If you don't have any way to get a spacer in between them. Why not drill a large enough hole to get the flat washer, lock washer and nut through the inner panel. That way there will be no tendency to distort either one.
Old 05-02-2012, 02:06 PM
Then if I use a larger washer or fab a plate to the curvature of the trunk lid it should provide plenty of support. Thanks Long John, thats a good idea.
Old 05-02-2012, 02:32 PM
Is there anyway you can use a stock "hinge"? There is nothing more simple, all it used was a bolt/pin that went straight into the corner of the lid in the and it pivoted on it!
Old 05-03-2012, 11:00 AM
I think I know what your describing. It probably would be easier but not the bling factor I am hoping to achieve with gate type hinges. Havent found the right hinge yet but I can picture it perfectly in my head.
1948 Chevy Trunk Hinge hucks 50 Body - Exterior 5 11-17-2010 05:58 AM
37 Dodge trunk hinge help New Bird Body - Exterior 1 08-23-2008 08:14 PM
Model A Trunk Hinge Installation simk Body - Exterior 2 04-01-2008 08:04 AM
Trunk Hinge jblair Hotrodders' Lounge 0 03-10-2002 10:02 AM
