Help tuning my SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2007, 04:27 PM
ScottRods2945's Avatar
Help tuning my SBC
I got my truck running a while back and found that I had to change my stahl converter so I did now I have it running and everything but it still seems to need a little tuning. It idles well, after it gets warmed up of course, but when I rev it up it wants to stay reved, for example, i barely touch the pedal and it revs high and stays reved for a little longer than it should. Instead of going up and coming right back down the RPMs go up and slowly come down. Another thing is that when I shut off the engine it didn't die immediatly it turned a time or two then spit up through the carb and smoked out of the carb. I have checked for vacuum leaks over and over and haven't found or heard any and I tried a fuel regulator and it didn't run any better. the carb on it is a carter afb comp series.
Old 05-14-2007, 08:32 PM
High idle
Had the same problem on a 290 HP 350. The intake manifold was warped creating a vacumn leak in the valley, changed out the intake and problem was cured. I would check everything else before I tackled the intake.
Old 05-14-2007, 09:26 PM
if there is nothing binding at the accelerator pedal, cable, or linkage
slow engine deceleration is usually a lean condition
play with your timming with the dieseling problem
Help tuning my SBC ScottRods2945 Engine 3 04-19-2007 01:02 PM
Tuning SBC? SuperSport Hotrodding Basics 3 11-26-2006 10:29 AM
tuning 327 SBC 1 Day Engine 5 09-23-2006 01:23 PM
SBC Tuning Help... dastone Engine 14 08-22-2006 05:12 PM
Dual Quads on SBC - Tuning? SirSpeedy Engine 1 04-13-2006 10:14 PM
