Help tuning my SBC - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2007, 05:28 PM
ScottRods2945's Avatar
Help tuning my SBC
I got my truck running a while back and found that I had to change my stahl converter so I did now I have it running and everything but it still seems to need a little tuning. It idles well, after it gets warmed up of course, but when I rev it up it wants to stay reved, for example, i barely touch the pedal and it revs high and stays reved for a little longer than it should. Instead of going up and coming right back down the RPMs go up and slowly come down. Another thing is that when I shut off the engine it didn't die immediatly it turned a time or two then spit up through the carb and smoked out of the carb. I have checked for vacuum leaks over and over and haven't found or heard any and I tried a fuel regulator and it didn't run any better. The carb on it is a carter afb comp series.
Old 05-14-2007, 06:43 PM
Run-on, slow idle return, and vapor after shut-off are signs of the butterflies are opened to much. To me it sounds like the idle circuit is to rich. I never messed with a carter afb before though.
Help tuning my SBC ScottRods2945 Engine 2 05-14-2007 10:26 PM
Tuning SBC? SuperSport Hotrodding Basics 3 11-26-2006 11:29 AM
tuning 327 SBC 1 Day Engine 5 09-23-2006 02:23 PM
SBC Tuning Help... dastone Engine 14 08-22-2006 06:12 PM
Dual Quads on SBC - Tuning? SirSpeedy Engine 1 04-13-2006 11:14 PM
