Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help on Tuning Please..
Old 08-04-2009, 08:43 PM
WDCreech's Avatar
WDCreech WDCreech is offline
Grumpy Old Goat Herder
With out knowing more about your engine, I haven't got a clue. What is the actual compression ratio, iron heads or aluminum, the cam duration @ .050" lift and where is it installed? The chart showed your peak horsepower at only 4500. That sounds low to me. The bottom end stumble could be a lack of accellerator pump shot.
