Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help on Tuning Please..
Old 08-10-2009, 11:50 PM
66Ponty's Avatar
66Ponty 66Ponty is offline
Solved the pinging problem. I worked with a helper this time and was able to rev it up to 3000 to set the timing, instead of working with it at idle. I tuned it down to 32 degrees and it is running like a champ.
Now on to jetting the carb.
Thanks again guys. You made things a lot easier!!
