help with unilite install on pontiac - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-28-2003, 07:31 PM
Post help with unilite install on pontiac
Can someone please shed some light on this for me. I have 67 lemans, wanting to install a mallory unilite I have and bought a mallory electronic coil (29216) for it, Coil that I had in car says "only for points ignition". Do I need any other componant other than the distrubutor and the coil for this set up. I can't get any juice out of the coil when I hook it up, finally just took it out put oem distrubutor back in and here I am. I tried hooking up coil w and w/o ballast resistor and still nothing, so far I haven't gotten any spark from coil to even see if the unilite is good. Any advise would be super, I really want to get rid of these points. Thanks for the help....
Mike
Old 04-29-2003, 02:05 AM
roys63's Avatar
Post
Maybe you have a bad Coil!!
Old 04-29-2003, 12:07 PM
New Member
Post
Is the Unilite new? They are infamous for packing up,usually because they have been run without a ballast resistor.
Old 04-30-2003, 04:47 AM
6567GTO's Avatar
Tire Fryer
Post
Try the original coil for a test only (honestly I'm not sure what difference there is besides output). If you wired it improperly you may have fried the eye. I'm glad to see you have a ballast resistor though because that's usually what kills the pickup eye. You probably checked all your hookups several times butmake sure you have it wired properly.
