Help with Urethane primer - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2010, 08:37 PM
Im a paint and body novice so I apologize in advance if this is a stupid question.
I purchased a Keystone product called ProPrime that is allegedly a quality 2 part high build urethane primer. I tried spraying it with a cheap Ampro hvlp gun with a 1.4 tip and got a terrible texture. I literally could not make it run.
Next I assumed my tip was to small and tried it out of a cummins tool sale hvlp gun that I have for spraying tractor paint. It has a 2.0 tip.
This gave me more of a fan but actually gave more texture as well as boogers and strings.
The stuff seems to want to plug up the holes on the sades that set the fan position.
I have tried every adjustment on the gun from entirely one way to the other.
Tried air pressure for 10 to 50. Nothing works.
I believe this stuff should be reduced however the supplier(keystone) says no.
What say you guys? I really have to get this jeep done and this is holding me up badly.
Old 08-20-2010, 06:58 AM
deadbodyman's Avatar
Wiki Edits: 11
reduce it anyways those guys dont know jack.Use a urathane grade reducer.
try 10% and spray some ,then 20% untill it starts working...sounds like old stuff but keystone products kinda suck anyways...
Old 08-20-2010, 09:31 AM
crashtech's Avatar
Technician
Last wiki edit: Epoxy primer
Wiki Edits: 17
The directions are to comply with the law. A small reduction with good reducer is called for, use the least amount that makes it work for you. With the 2.0 tip, even 5% may make a drastic difference.
Old 08-20-2010, 07:38 PM
2ndchanceauto's Avatar
body and paint guy
Last journal entry: delivered
keystone can't even send a part for the correct side of the car i can expect them to have good primer. ppg,dupant,basf,standox,HOK,sherwin williams,even nasson would be better.imo
Old 08-20-2010, 08:20 PM
Wiki Edits: 11
ILMAO,I hate to say it, but hes right .....you even have to check and see if its the right make and year...I swear,sometimes they'll throw anything on the truck...it got so bad we picked our stuff up ourselves..
Old 08-21-2010, 03:55 PM
Thank you for the tips. A mix of 4.1.1 was just what he doctor ordered for the 1.4 tip.
Old 08-22-2010, 05:59 AM
Wiki Edits: 11
my tip is a 1.4 too...but for off road you should really try some SPI epoxy,and it wont chip or scratch so easy...it builds,sands and blocks well also ,unlike other epoxies..everybody that trys it,lovees it..itcan even be used as a sealer...One primer for all jobs...
Old 08-23-2010, 04:44 AM
Where can I purchase it? How is it priced? Honestly Im using th e cheapest crap i can find as rocks arent very forgiving on body panels and paint.
Old 08-23-2010, 04:54 AM
Wiki Edits: 11
call them to see if its available where you are or you can order it ,but I promise you its worth the wait ....it runs about 180.00 for two gallons ,one gallon of primer and one gallon of activator. mixed at 1:1 tel# 404-307-9740
I've abused this stuff every way I could think of and it still works great...even piled on 8 coats back to back it had no affect ,just took longer to dry.I wont use anything else....
Old 08-23-2010, 07:15 AM
crashtech's Avatar
Technician
Wiki Edits: 17
If rock chips are a major concern, doing some research to find the most chip resistant materials may pay off well. Epoxy primer tends to be more chip resistant than other primers in general.
Old 11-10-2012, 09:20 PM
I just tried to use this stuff. Saying it's thick is an understatement. To get it to spray out of my Harbor Freight "Pro Auto" series guns, I had to crank pressure up to 45 at the gun, and run a mixture of 4:1:3. Yup....three paint thinners.
Old 11-10-2012, 09:40 PM
novafreek6872's Avatar
Nova Guru
This is an old thread, but I learned a thing or two here. I also had trouble spraying 2k...now I know what to do! Thanks Guys
Old 11-11-2012, 05:49 PM
Oh, they also told me it didn't need to be reduced either. Then, I got a smarter guy on the phone and he said to just add paint thinner until it sprayed reasonably. As noted earlier....4:1:3 was what I had to do. It sprayed as if it was a wall-texturer until I hit 4:1:3.
I also tried pressure ranges from 10-60, and it wasn't until I hit 3 parts reducer that it worked. It was a mess until then.
Then, once we got it spraying....it went on very nicely and it sands great--leaved a nice finish once you get it prepped. I went 320, second coat of primer, then 400/600.
I'll put color down in two days....Wandabase. We'll see how it goes.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Epoxy vs Urethane Primer UKLuge66 Body - Exterior 41 11-23-2008 05:50 PM
Urethane Primer cu42 Body - Exterior 4 07-18-2007 08:31 PM
Question on primer for a urethane body kit hotrodf1 Body - Exterior 2 04-17-2007 07:57 AM
Urethane primer and body filler Lator_Gator Body - Exterior 23 01-08-2007 02:15 PM
