Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help using my B&M Ratchet Shifter!!!!!
Old 11-11-2003, 06:48 AM
funatnight funatnight is offline
New Member
It has been awhile since I used a ratchet shifter but here it goes.... The little red lever is the reverse lockout lever. Hold that down while shifting to get the shifter in reverse. From there you can shift into park by lifting up on the shifter and moving it forward (I think). If you are in reverse and you want to go into the gears you just pull back to go through the gears.
I hope that this helps out.
