help with vacuum line to heater in '72 camaro
just got my car back. been so long since i took the engine out and also got it painted i dont remember where half this stuff goes. my heater fan comes on weakly, seems like it came out more before. not much heat either. anybody know some things i can check out? thanks
thanks. i just discovered my blower is actually working when it is NOT in high. other sites tell me this means my 72 camaro needs a new high speed heater relay. also tho, i have a @#12 orange wire going towards my blower. it has a rubber female spade connector on it. i dont know where it goes or what it does. apparently it doesnt work the blower since i have fan goining at med.hi, med, and low speeds.
Hey bull,is your outside air door in the cowl closing or staying open at all times?
i dont know! where is it? i dont know where it is. i dont have any cold air coming in so it must be closed.
It is inside the heater box,it closes off air from th eoutside coming in.It is the fresh air vent door.It must be working correctley if you do not feel a rush of cold air on your feet.There may be a vacum servo on the bottom of the box.I thought my 76 and 78 both had manual operators.My 79 Malibu has the vacum though and it is all wacked out.Like Mr Ed stated back flush the heater core,take the lines off at the Bypass and intake,blow through them,it may ytake a second to get the coolant out,use a bucket so you do not splash that slick stuff on that $10,000 paint job though.Use mouth not compressed air.That way you can feel the resistance.If it is hard like blowing up a beach ball,the core is plugged and needds replaced.If you can blow through with no reisitance it is fine.
haha, i dripped some on it checking the protection level but wiped it off. i was wondering to myself if anti-freeze would screw up the paint.
anyway it does heat. just not on high speed. i'm sure i need a hi speed relay as above. i'm just wondering about a couple other things. the orange wire with the spade connector on it under the hood near the blower motor and the vacuum line on the inside of the car near the center hanging down with a red stripe on it. |
Drawing a blank on both bull,sorry.See if I can find something in a manual on Camaors.I have one in my utility room.Goota head off to work now,it is 8:00 PM.I HATE nite shift.
| Recent Interior posts with photos |
