Help with Vortec Heads...please!! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 06-19-2010, 05:18 PM
cool rockin daddy's Avatar
Third, do yourself a favor and get a good book on hotrodding chevy engines. You will discover that raising or lowering the compression ration does not make that big of a hp difference. You gain a whopping 4% hp increase with a full point increase of compression. On a 400 hp engine that equates to 16 hp. Milling heads has it's limits as you can mess up the angles of the mating surfaces between heads and intake manifold. Not worth it. Get Lingenfelter's book on "How to Hot Rod Small Block Chevy Engines".
  #17 (permalink)
Old 06-19-2010, 05:59 PM
Get a book huh? lol - thats funny! Everything else you said is well known info, im talking about VORTEC heads, and Vortec heads ONLY, no 2 heads are the EXACT same, especially when machining. 4% on a 215hp 305 is about 8.5HP, i'll take that! After modding it will be worth 15hp, well worth worrying about. I would also say a 8.2:1 305 runs like $#!t. I know about intake alignment issues, its fairly easy to fix by hand without hurting flow. Also, telling someone to get a book over a particular head question is BS. I hope you are just meant to help out and that wasnt meant as an insult.
  #18 (permalink)
Old 06-19-2010, 07:45 PM
No, it wasn't meant as an insult. However, your tone is increasingly becoming one where an insult would be deserved. I suggested the book because you are all over the map on your questions. First you ask about 305 vortecs. Then you start talking about vortec baseplate for TPI. Then you say you are bucks down. Then you talk about reworked S/R Torquers. Now you ask about milling heads. You sound like you DON'T have a plan, DON'T understand basic engine hotrodding, and you DON'T have any money. Am I wrong on any of those assumptions? If so, I apologize. If not, get the book I mentioned, read up on it, make a plan for your engine, and make a budget to make it happen. If that sounds like an insult to you or too harsh for your sensibilities, that's on you NOT on me.
  #19 (permalink)
Old 06-19-2010, 09:26 PM
Silverback's Avatar
Boost Retard
Those numbers are killer for a factory 305 head... roughly 40cfm more on both the intake and exhaust than many other 305 heads, and for the most part, the pre-vortec, 80's and 90's 305 heads were better than a lot of the similar vintage 350 heads.
For that matter a friend of mine spent a few hours just doing some basic clean up with a carbide bur (no sanding or real heavy work), installed some 1.94/1.55 valves... they flowed 260intake, 222exhaust at .500" and made 460hp on a well built 350.
  #20 (permalink)
Old 06-19-2010, 10:29 PM
Valkyrie5.7's Avatar
www.generationhighoutput. com
Last wiki edit: Painting chrome wheels
Last journal entry: Stopping my journal entries here
Wiki Edits: 15
The 059s do flow well but I wouldn't take those numbers I posted as gospel. I didn't personally test them myself nor do I know the source from where they came from before they wound up on the Stan Weiss chart. I would consider those figures for "educational purposes" only.
  #21 (permalink)
No actually, its just not having a plan at the moment. I am not broke either, I am trying to do a 305 for once, seemingly how it will never run like a new LS3, or a coyote with any form of redeemable driveability. So I am shooting for mid 13's, to keep most imports at bay. Atleast, most honda/acura products. I graduated UTI, worked for Prewitt, then ProTech, then dyno operating at CCS, then (now) doing Top Fuel Hydro (#777 Disorderly Conduct) with family. I know cars, and performance, just NOT 305's with Vortec heads. From what I have gathered, the STOCK 081 castings are flowing 195/110. With headwork and a valve job its possible to make 240/155, which SHOULD be enough to take this 5 Liter GM in the 13's. Intake choice is going to be key, with a ported base thats siamesed, siamesed runners, and a port job on the plenum with throttle body, full exhaust and some 3.42 gears... I may have close to it. Add a stall and some trans work with a stick tire, and it MAY be there. Lets not forget the custom prom tuning... NOW... This IS simply nothing but a guesstimation.... I dont like gambling with a 305, or my money ON a 305... See how this can be irritating and warrant questions?
Silver, thats awesome! Pretty close to what i'm looking for...what do you guys think about the 1.94's in a 305?? Shrouded? Do you think some better valves with a nice seat job (4-5 angle) valve job in other words with some 1.84's would be better?? The cam is most likely a 206-216 .450 @112... something the TPI knows what to do with.. Maybe more but not much thats for sure.
  #22 (permalink)
Old 08-13-2010, 01:08 PM
Update: It hasnt been easy, every corner I turn, every guy I get a price from etc. etc. points to one thing... 350 swap. The best I can do, is to NOT spend any significant money on a 305 and do head porting and intake porting by myself. The EQ 305 heads flow about what stan weiss says, but they are in fact $715.00 assembled. Mix that with a vortec intake for $375 and it's a no go.
So- I bought a 350 vortec 882 block and crank. It needs new rods and pistons etc. but at least I wont be throwing my $$ away.
I figure a 355, flat tops, 270 cam, vortecs and a decent exhaust with TPI would get somewhere. The turd gen cars are so heavy, it should be mandatory anyway.
  #23 (permalink)
Old 08-13-2010, 10:30 PM
Imagine that, got smart and went with the 350. Good move.
  #24 (permalink)
Old 08-14-2010, 01:14 AM
Yeah, now I need some heads, im think the RHS pro torker's would work.
  #25 (permalink)
Old 08-14-2010, 09:23 AM
I would consider a slightly smaller cam with TPI. Also you'll want a reverse split on the cam, like running a restricted intake.
  #26 (permalink)
Old 08-14-2010, 09:41 AM
sorry, yeah xe268 at most.
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 03:17 PM
Cam and valve springs - Vortec heads? staleg Engine 8 02-17-2010 07:31 AM
906 casting Vortec heads and overheated (?) rods darefugee Engine 1 11-09-2009 03:49 PM
Vortec Heads or ??? for SBC Old Rotor Flap Engine 2 10-25-2009 04:25 AM
Exclusive parts for Vortec heads mgray Engine 1 10-16-2003 06:38 PM
