help w/ holey gas tank
hi desperately need help with this question i have a hole in my fuel tank how can i get it fixed cheaply and quick????
Soozie, we need a little more info. What type of vehicle are you dealing with? Is is a large, hole, what size? Is it rusted? Punctured? seam separation?
You may have to buy a new tank. some shops can weld them. JB weld may work on some leaks. Is it a fairly common vehicle? Wrecking yards may be the answer. Those guys should practically give them away, i don't believe they can crush the car with the tank in place. I hope this helps a little. I edited your post for clarity, a lot of folks won't bother with just "help" in the subject line. If you find the time, our search engine will give you many alternatives as to the ones I posted. Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
NAPA has a tank repair kit that will work with the tank in the car if it is just a small hole...I have used it with some success..
Sam
| Gas tank filler | guba_unus | General Rodding Tech | 4 | 05-13-2008 06:47 PM |
| Diesel pumped in new Corolla Gas tank | michael2 | Engine | 21 | 05-05-2008 11:29 AM |
| POR-15 gas tank resto kit | cruzinTLT | Body - Exterior | 1 | 06-06-2006 05:08 PM |
| Gas Tank 1970 Chevy Camero | kan | Engine | 0 | 05-21-2006 11:57 AM |
| gas tank pressuring up | montea | General Rodding Tech | 3 | 06-04-2004 08:37 PM |
