Help w plug gap - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-29-2012, 01:12 AM
Help w plug gap
Does any one know what type of spark plug and the gap would be good for a 388 stroker with 1.60 ext.and 2.02 intake aluminum heads??
Old 02-29-2012, 08:32 AM
bondo's Avatar
Ayuh,.... With the extremely limited Info,....
I'd start with the spark plugs Chevy has used since the invention of Dirt,....
The AC Delco, R43T.....
Or,...
The Alloyed bodied MR43T...
Old 02-29-2012, 12:00 PM
Wiki Edits: 49
Chevy, Ford, AMC, Lamborghini, Ferrari, Bugatti, Mopar??????? We're not mind readers.
Centerline
HotRodsAndHemis.com
"Life is hard..... and it's even harder if you're stupid." - John Wayne
Old 02-29-2012, 10:51 PM
Thanks!!
I knew!!!! just trying to make sure thanks!!!
Old 03-01-2012, 11:03 AM
dinger's Avatar
ATX, you need to be a bit more concise with your topic subject when you start a thread if you really want guys to answer the question. Using titles like "Help" or "question won't get you far. I am editing these so you can get an answer or 3, please do this in the future. Thanks, Dan
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 03-02-2012, 01:52 AM
Spark plug gap 388
I was just woundering is the gap on a regualr 350 witch is .45.. Does that apply with the 388
Old 03-02-2012, 03:46 AM
poncho62's Avatar
Wiki Edits: 5
For the street, I would say yes......
Old 03-03-2012, 12:09 PM
Landshark928's Avatar
FrankenPorsche
Wait, a R43T is a 14mm 5/8" reach tapered plug. Many SBC aluminum heads take a 14mm 3/4" reach gasket plug. Like AFR and Procomp. If you use the wrong one you may end up with the plug being shrouded in the hole.
OP, we need to know what brand of heads you have.
Old 03-21-2012, 10:48 PM
pro comp
I have some pro comp heads 2.02 and 1.60 I always hear pro comp junk!! I don't know!! I will find out how much junk it really is because I'm gonna put it to the test for show.Blow or go baby!!
Old 03-22-2012, 04:17 AM
Richiehd's Avatar
JS-70
You didnt get a spec sheet from Pro comp listing what plugs,head gaskets, guide plates stc?
Old 03-22-2012, 10:03 AM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
WOW a half inch gap?!?!?!
J/k I am sure you mean .045"
Has anybody ever seen this plug before?? 0pyders Electrical 5 03-02-2011 12:53 PM
plug and plug wire removal tcoop Engine 4 10-22-2009 08:01 PM
Two Plug Alternator coverted to four plug L_Maddox Electrical 6 04-27-2007 08:16 PM
Why straight plug heads and angle plug heads 406chevelle Engine 6 03-19-2006 12:36 PM
Gmspark Plug - Hotter Plug? joe brienza Engine 1 04-13-2005 10:58 AM
