help with weiand 671 torque specs - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2006, 02:07 AM
malibu68's Avatar
i just want to make sure i am bolting everything down to the right specs,
i need to varify :
Top carb mounting plate
carbs to mounting plate,
supercharger to intake manifold
intake manifold to block
and last the idler pulley arm to the supercharger
Old 07-21-2006, 08:56 AM
camaroman7d's Avatar
Manifold to head bolts 25ft lbs
Carb adapter plate 15-18 ft lbs
Blower to manifold bolts 10-12ft lbs
idler bracket to blower 25ft lbs
idler pulley to bracket (large bolt) 40ft lbs.
Hope that helps
Royce
torque specs. , 88' chevy 350 leonard69 Engine 1 05-27-2005 11:30 AM
Anybody have wheel torque specs? TurboS10 Hotrodders' Lounge 5 03-08-2004 02:08 PM
Torque Specs Phyrkrakr Engine 5 07-25-2003 07:54 PM
Torque Specs...Engine Builders TurboS10 Engine 10 03-08-2003 02:21 PM
VETTE REAR END TORQUE SPECS reegeemon Transmission - Rearend 1 12-23-2002 02:32 PM
