Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help with weird oil leak
  #23 (permalink)
Old 02-15-2013, 08:28 AM
Coram Stiner Coram Stiner is offline
I know this may sound a little off the wall but thier are 2 things that I have run into with my sbc 1. wrong rear seal 2. there is a spot on top of intake manifold for egr valve back by distributer. It is recessed into manifold with 2 bolt holes these dont go thru casting (not suposed too) 1 of mine opened up some how and at higher rpm would throw oil out. you can only see it if you stand on drivers side hood open and rev up motor with throttle linkage. I hope this helps. PS. there are 2 different rear main seals
