help welding tubular steel
hi folks, i am in the planning stages of building a frankenstein from a 4 wheeler and a 750 honda inline 4, on what will appear like a honda odyssey frame.
i want to use tube steel instead of square stock because bends will look better than angles welded. my question is, to make a "t" joint ,how do you remove the semi-circle shape from the adjoining piece ??? do you drill the steel and then cut it off??shape it with the grinder ?? blow it out with the stick welder? i just thought there might be an easier way to get the shape. or will it matter when it's welded. thanks guys, mike |
Mike,
There are a few ways you can do this: 1. You can drill/mill then grind to your line with a drill and vise. 2. They actually sell (eastwood) a tubing notcher for your drill press. 3. Williams Lowbuck sells a different notcher that takes a bite out of the pipe! This is the fastest way to go. They sell about 5 different sizes depenting on the tube size and thickness. Hope this helps, Seth |
thanks guys,the die grinder is probably the best bet for me,thanks again for the info. mike i do have a bimetal holesaw too...
| Recent General Rodding Tech posts with photos |
