we'll need a bit more info to give exact advice. but you would mix the primer at the suggested ratio... if it's an epoxy, it would be about a 1:1 with the activator.. but it'll show the exact on the can... as far as spray gun. if it's a standard gun, ither siphon or gravity.. right around 45-60 PSI the gun will operate.. I always wetsand with a little dish soap and 220-400 grit. depending on how rough it is... the procedures are all pretty simple but complicated to someone who has never done it before... my suggestion would be to get on good terms with your brother, and then have him teach you.. it's not hard to learn. but you really can't teach youself.. I did, but I practiced by painting junk fenders till I got it right
