Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Help! What To Do With These GIGANTIC Dents!?
Old 09-13-2005, 08:33 PM
mistermuscles's Avatar
mistermuscles mistermuscles is offline
Last journal entry: I'm Baaack!!
Originally Posted by Centerline
Don't fill a dent that deep with bondo. It will crack, and probably fall out one day while you're trucking down the road.
Take some time with a body hammer and dolly and pound the dents out as much as possible. When you get the surface smooth enough that 1/8 inch of bondo will do the job you're there. In any case don't go over 1/4 inch thick with bondo, it's just not made for filling such deep depressions.
Ahh, thanks for the advice.
That will work for the door, but the pictures do the trunk justice. The whole bottom of it is rolled up, and it's really bad on the right side of the trunk.
I was thinking of just buying a new trunk all-together, but it's pretty hard to find one, and whenever I do, they are just way too expensive for me.
