Help Wifes Jimmy Won't Start - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2003, 11:31 PM
Question Help Wifes Jimmy Won't Start
<img src="graemlins/spank.gif" border="0" alt="[spank]" /> 1996 GMC Jimmy (Central Mutliport Feul Injection) did cap, rotor, plugs, wires, and fuel filter. No help, still won't start. So i thought fuel pump but you can hear it running. So now i'm thinking Nozzles but when the thing does start it runs just fine, so nozzles are good? no check engine light nothing. But you let it sit for a while and it won't start again. Now it won't start at all. and yes the check engine light does work it come on during system check. any help would be nice Thanks Jumboset
Old 05-03-2003, 01:42 AM
Pontiac Knowledge Base Editor
Post
Try the module under the distributor cap.
Old 05-03-2003, 07:31 AM
New Member
Post
u can hear the f/p runnin but does it have enuf pressure?
Old 05-06-2003, 04:20 PM
milner's Avatar
Post
try narrowing it down. test fuel pressure, check for spark at plugs. i have had a few of these with the same problem. all had a hole burnt through the coil tower. good luck!
