help... will turn over but not start - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2007, 02:10 PM
I have a 62 Nova with a 350 chevy engine. I have replaced the ignition, ignition swicth, neutral safety switch, rotor, points, cap, condensor, new wires from starter to coil, coil to distributor, but its still not getting any spark.The coil is reading 3.7 volts. Help.....What am I missing?
Old 04-29-2007, 03:46 PM
Wiki Edits: 31
jump the coil to 12v from the battery, if it starts up and runs, leave the key on, but remove the jumper from the battery, if it stays running, there is a problem with your bypass circut, if it dies, there is a problem with the ballast resistor or resistor wire whichever it has.
Old 04-29-2007, 04:53 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
If your only getting 3.7 volts at the coil, (and at that can I assume this is a points type ignition?) Your Coil is shorted....
For a Remote type coil (Points type) , pull the wires off the coil, Get your DVOM out, set it For OHMS, R X 1 Scale, Calibrated for "000", Measure the primary side of the coil.
The reading here Needs to be Less than an OHM, but MORE than "000", If it is MORE or Infinite (OL) , It's Bad, or Soon to be..Toss it..
Next Measure the Secondary, SET your SCALE for R X 10 K or higher, It Should Read, Between 10,000 and 11,000 OHMS Lower or higher ... Toss it, it bad .
IF you have an HEI, The testing is different, Remove the cap, invert it and get out your DVOM, Set it for OHMS, R X 1 Scale, Calibrated For "000",
Place one probe on the BATT terminal, the other on the TACH terminal, The reading here should be LESS than an OHM, But More than "000" .. Higher or lower, it's Bad..
Next Measure the secondary, Set your Scale for R X 20 K or Autorange, Measure between the BATT Terminal and the Carbon Element for the rotor pickup in the center of the cap , this reading should be between 6,000 ohms and 31,000 Ohms..less or more , toss it , it's bad..
Another Possibility Exists, IF you Installed an HEI, in a 1962 Body, Chances are your Ignition wire was set up for points type Ignition..
This being the case, It will have a Ballast resistor on it OR the Wire itself will be a resistance wire (some are cotton Clad and marked Resistor Wire Do not Cut) , IF this is the case, Remove the Wire OR Ballast resistor (Trust me on this, the resistor wire police won't be knocking on your door.. ) Hook it DIRECTLY to the Cap BATT terminal..
An HEI will not run with a Ballast resistor in line..Or run like Crap in a can...If you want to test the theory before surgically altering your harness, just run a jumper from the BATTERY + to the BATT terminal on the cap, Crank it, it should start and run..To shut it off, you need to pull the jumper..the Ignition is bypassed ..
If it starts and runs, Remove the Ballast, and run a 10 Gauge wire in it's place.
Doc
How Does This Stuff Work? docvette Electrical 3 06-18-2006 03:00 AM
crazy right turn signal fasteddiesage Electrical 6 02-07-2006 10:33 AM
turn signal blowing flasher fuse RodFather Electrical 12 05-13-2005 06:23 PM
Won't Start fasano89 Engine 4 11-28-2004 11:57 AM
Wiring Tail Lights & Turn Signals horvath Electrical 15 04-30-2003 05:04 AM
