Help with Wiring a Dixie Horn - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2008, 06:26 PM
I need help wiring a dixie horn with a push button so can keep my exsisting horn.
I installed a 30 amp inline fuse.
the horn works great wired direct to the battery.
but i have no power from the relay to the horn button.
Old 01-13-2008, 06:40 PM
31 five window
Last journal entry: grill and rear end
Does your relay have 4 or 5 male prongs.
Old 01-13-2008, 08:18 PM
It has 4. 30 87 85 86
I have 30 to the inline fuse
85 ground
and 87 to the horn push button and compressor
and last from the top of the compressor to the other terminal of the horn button.
I don't have 86 hooked up to anything because i want to keep my exsting horn
Old 01-13-2008, 08:30 PM
31 five window
Do you have your factory horn button hooked to both horns? They will blow at the same time. If you want to keep your factory horn you should have another horn button for your Dixie horn. Your Dixie horn should be well mounted and grounded.Hook the hot wire from the compressor to 87. From the battery with an inline fuse hook a wire to 30. Hook a ground wire to 85.Hook a wire on 86 and run it to one side of your new horn switch.Hook the other side of the new horn switch to a hot wire.Blow your horn. If you don't use all 4 hookups on the relay it is useless.
Old 01-13-2008, 08:36 PM
thanks
Thanks for the help...I'll give it a try...
Old 01-13-2008, 08:39 PM
31 five window
You are welcome.
Old 01-14-2008, 01:51 AM
Job~Rated's Avatar
Artful Dodger
Last journal entry: From behind
Welcome to the site, stacky!
Wow, what an intro....
Old 01-14-2008, 09:44 AM
Thank You
Originally Posted by speedydeedy
You are welcome.
The horn works great now.
Thanks again,
Dale
Old 01-14-2008, 12:22 PM
Welcome to Hotrodders How about a sound clip when you get it workin.
Shane
Old 01-14-2008, 02:08 PM
31 five window
You are welcome Dale. I don't know everything but i am good at 12volt electric. I worked as a Johnson outboard mechanic for 20 years and had my own electrical supply company for 12 years.
Replace existing horn w/ ooga horn? BobbyG-39 Electrical 14 11-03-2007 01:58 PM
I need help about GM horns..wiring aftermarket horn GMCANYON Electrical 5 04-27-2007 08:11 PM
wiring horn flyboy26 Electrical 4 03-14-2007 07:46 AM
69 GM Column Horn Problems Campbem Electrical 7 12-31-2004 11:25 PM
wiring a horn to the steering wheel 73chevyhelp Electrical 3 04-09-2004 10:36 PM
