hemi rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-10-2013, 09:40 PM
hemi rear end
street legal sprint car with an old quick change that needs some work (it was dry when i got it) the quick change has "HEMI" casted into it, all i can find. is anyone familiar with this mfg? probably out of business but if i can find someone with knowledge of them and maybe locate some old parts or anything would help. thanks
Old 03-11-2013, 06:00 AM
big gear head's Avatar
High Performance Rear Ends
Tiger Rear Ends
Contact these people and see if they know anything.
The Following User Says Thank You to big gear head For This Useful Post:
Crosley (05-28-2015)
Old 03-11-2013, 10:51 PM
Hemi rear end
I have 2 of these Hemi rear ends that I bought years a go, these rear ends where made in Southern California in the 70s by a brother of a sprint car driver that keep braking there Halibrand quick change. Hemi is the abreveation for the name of the Company but I can not remeber the name but I will ask around. Let me know what you need I will try and help. Thanks
Old 05-28-2015, 01:08 PM
Additopnal Infomation
Gentlemen: Any of you have any picures or additional information on the HEMI Quick Change ?
Old 05-28-2015, 05:26 PM
poncho62's Avatar
Wiki Edits: 5
Googled a couple of things......
"HEMI used 12-bolt GM ring/pinon gears as opposed to Ford style gears traditionally used by Halibrand, Winters, et.al. Other than that they used the same 'change-gears' as the others. The main problem (as far as Sprint/Champ car applications) was weight: they were appreciably heavier than traditional Halibrand/Winters Q-C's. They were fairly recent(late '80's- early '90's ?) so bearings & gears should be readily available, & they are certainly strong enough. If you have a 'stock car/modified' unit with a differental & axle housings you're in good shape: if you've got a solid axle(open wheel) unit you've got some searching /fabrication/conversion chores ahead. I see in your picture that you have an 'open-wheel' version: you'll need to adapt/fabricate axle housings( possibly use a 12-bolt rear axle for donor parts?) & add a differential for the street."
Old 08-20-2015, 12:34 PM
HEMI stands for Harrison Engineering and Marine improvements. It was owned by a good friend of mine by the name of Bill Harrison. His brother's name was Dean Thompson a driver from the LA area. The full size HEMI quick change used DANA 70 gear sets, not GM 12 bolt gears. He also built a Midget quick change that was smaller. I reduced the midget down and make a 1/4 scale quick change.
The main problem with the full sized HEMI rearend was that it used Hypoid gears not straight spiral bevel gears. In a quick change the gearset gets flipped over and the driveshaft goes under the pinion. Being Hypoid the pinion gear moves up in the housing causing the driveline to move up in the car. This caused a problem in sprint cars of the driveline tube wanting to hit the seat.
The Following User Says Thank You to hcvrr For This Useful Post:
big gear head (08-20-2015)
stock 63 chevyII rear end vs. s-10 rear end david6chevy Transmission - Rearend 3 08-17-2009 04:36 AM
Gm 12 bolt truck rear end vs. car rear end '54 Pontiac Transmission - Rearend 6 02-05-2009 05:17 PM
4x4 12 bolt rear end same as 2wd rear end??? Ed ke6bnl Transmission - Rearend 2 05-24-2008 02:25 PM
End of the 57 Hemi Project 1957plymouthhemi Hotrodders' Lounge 9 11-10-2006 06:06 PM
Ford 9" rear end vs stock 89 chevy truck rear end jimmy p Transmission - Rearend 2 12-07-2005 03:28 AM
