Hemi trans? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2003, 08:32 PM
bad429's Avatar
Hemi trans?
I recently bought a 392 hemi. Atatched was this ?????? my grand father says its a section or part of a fluid or hydro drive(semi automatic) what does that mean. Never saw a tranny that was auto AND standard. Has any one used these things. I bought a adapter and bell housing to use a 727 so i dont know what im goig to do with this.
Old 06-10-2003, 10:01 PM
willys36@aol.com's Avatar
Wiki Edits: 21
That was one of Chrysler's early (bad) attempts at an auto tranny. Has no value except for restorers. Put it on ebaY. Some sucker will fork out money for it.
Old 06-11-2003, 09:12 AM
Wiki Edits: 49
If your hemi came with that trans installed I'd double check the ID numbers on the front of the block to make sure it's a 392. I don't think any 392's came from the factory with the fluid drive trans. Only early 331's.
Centerline
http://www.hotrodsandhemis.com
Old 06-11-2003, 09:19 AM
bad429's Avatar
Yea the engine is a CE57 the engine is from a imperial but ended up in a earlier new yorker.
Old 06-11-2003, 09:24 AM
Wiki Edits: 21
Centerline
Good point. '57 & '58s (only years that 392s came in) came with pushbutton Torqueflites didn't they?
Check the serial number stamped on the front of the block just behind the water pump. Will have a 'CXX' there , the 'XX' being year.
