heqadliner - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2006, 06:45 PM
heqadliner
has anybody ever used taht foam headliner stuff for a 57 chevy? I was thinking of using it somehow and glueing it to the rof, i have already torn the old liner out. do you think it would work or any advice?
Old 11-15-2006, 09:47 PM
DanTwoLakes's Avatar
Wiki Edits: 22
Are you talking about foam backed fabric headliner material? If so, yes you can use that to make a headliner, but you would be better served to use a pre-made headliner to fit your car. They are not that expensive. Try www.kanter.com under upholstery for a headliner for your car. They are $150.00. Good luck, and ask more questions if you need to.
Old 11-15-2006, 09:51 PM
Wiki Edits: 22
If you are talking about insulation or sound deadening materials, there are all kinds of them for every different budget. They can be applied directly to the roof before putting in the new headliner.
Old 11-16-2006, 11:50 AM
Wiki Edits: 49
Try using the spell checker. It's located to the right of the submit reply button. It will make your posts a great deal easier to read and you'll get more responses.
Old 11-17-2006, 05:45 PM
Trim Tech's Avatar
It would be best to replace your headliner with a factory "bow" type headliner as one it would give you the best look but you would need the bow's ( that you kept right? ) Option # 2 would be a solid healiner center only that give a street rod look but takes alot of work and skill to pull it off. I would recomend that if you replace the headliner to use a ceramic insulation( Lizardskin) above the healiner as foil or jute insulations tend to fall down over time and leave marks in the material poking out. One more thing replace the windlace befor you put in the new headliner.
Regards
Jason
Old 11-17-2006, 06:41 PM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
TrimTech..........Please read the site rules and policy regarding advertising.....Please remove your business url's Thank You Don't advertise your business. If you are affiliated with an automotive business, you may not post contact information for that business on public board posts, in your custom user title, or in your avatar. Business contact information includes, but is not limited to: physical addresses, phone numbers, email addresses, and URLs. Stating the name of your business is allowed, as long as the name of your business is not identical to any business contact information. If you are affiliated with an automotive business website, you may post that website's URL in your user profile page, and then you may refer people to your user profile page if your services are relevant to their question.
