-   -   Heres a challenge (http://www.hotrodders.com/forum/heres-challenge-7193.html)
jeff germano 03-17-2003 08:31 PM
Heres a challenge
My 81 el camino dies the other day after it ran for the first time in 6 months. It had good spark so i figured the old gas gunked up the carb so i rebuilt it. I disconnect the gas line from the carb and spray starter fluid into it and it doesnt even kick over. I take a plug out and i see good spark. What could the problem be? If its timing how could of it have changed it was just running crappy but it was running. please help
BstMech 03-17-2003 09:03 PM
[quote]Originally posted by jeff germano:
<strong> I disconnect the gas line from the carb and spray starter fluid into it and it doesnt even kick over. I take a plug out and i see good spark. What could the problem be? If its timing how could of it have changed </strong><hr></blockquote>
Spray the starting fluid/Ether in to the choke horn.......
4 Jaw Chuck 03-17-2003 11:40 PM
...and tap around the carburator with a screw driver, just lightly.
If that don't work...BOOST it! :D :p
senor_limpio 03-18-2003 12:25 AM
Probably a little late now, but anyway....
Pull all those plugs and let 'em dry out. (Might as well give those plugs a cleanin' while they're out!)
Seņor
[ March 18, 2003: Message edited by: senor_limpio ]</p>
BstMech 03-18-2003 11:49 AM
.....All the above..... :D
bigwildgrin 03-18-2003 03:24 PM
if you let your car sit for six months it could be water in the gas. this is especially true if the tank was half full or less; condensation forms on the inside of the tank if it is not completely full of gas. just a thought since you said it started and then died...
